Switch in Switch-Stack Will Not Join PowerStack
remitprosupport
Level 2
Level 2
Hello all...
I have a pair of C3750X's which are configured in a switch-stack (which is working as expected), but I'm having trouble getting them to join the same power stack.
I have the power stacking cables connected in the following fashion:
Switch1/Port1 ---> Switch2/Port2
Switch1/Port2 ---> Switch2/Port1
Neither of these has any PoE ports. They each have two 350W power supplies. I removed the original power stack from the configuration and created a new one. Here's the snip from my config:
stack-power stack powerstack
mode power-shared strict
stack-power switch 2
stack powerstack
stack-power switch 1
stack powerstack
When I run "show stack-power" this is my ouput:
ProdSw1#sh stack-power
Power stack name: powerstack-1
    Stack mode: Power sharing strict
    Stack topology: Standalone
    Switch 1:
        Power budget: 670
        Low port priority value: 22
        High port priority value: 13
        Switch priority value: 1
        Port 1 status: Shut
        Port 2 status: Shut
        Neighbor on port 1: 0000.0000.0000
        Neighbor on port 2: 0000.0000.0000
    Switch 2:
        Power budget: 223
        Switch priority value: 2
        Port 1 status: Shut
        Port 2 status: Shut
I've re-entered the commands numerous times, including specifically stating "no standalone" in the stack-power config mode, restarted, and still no change.
If anyone can point out what I might be doing wrong, I'd really appreciate it.
Dan
Somasundaram Jayaraman
Hi Dan,
The port 1 & port 2 status should be in no shut state for the formation of power stack. I see from your output that port 1 & port 2 is in shut state.
Port 1 status: Not shut
Port 2 status: Not shut
Power Supply Options for the Cisco Catalyst 3750-X Series Switches
Product ID
Description
C3KX-PWR-350WAC
350W AC power supply
C3KX-PWR-715WAC
715W AC power supply
C3KX-PWR-1100WAC
1100W AC power supply
C3KX-PWR-440WDC
440W DC power supply
Pls refer the below link for more details
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/white_paper_c11-578931.html
Hope this helps
Cheers
Somu
Rate helpful posts
smogra
As mentioned by Somu, your port status shows that they are in "shut" state. For them to work fine, they should be no shut.
    Switch 1:
        Power budget: 670
        Port 1 status: Shut << ---- shut
        Port 2 status: Shut << ------ shut
Execute the following command to get them working fine:
switch#stack-power switch <> port 1 enable
switch#stack-power switch <> port 2 enable
Please do that for all the switches in the stack where you replace the <> with the switch number.
Also check the power cable and its compatibility with the device.
Hope that helps.
Cheers
Sweta
Please rate the useful comments.
