switch in vtp client mode
sarahr202
Level 5
Level 5
hi every body!
Does switch in vtp client mode stores config revision number in vlan.dat or nvram?
i find some cisco documents which say client switch store config revision number in vlan.dat on flash while my cisco press book says client switch stores config revision number in nvram
which one is correct?
thanks a lot and have a nice day!
21 Replies 21
During my test, I also found the VTP Client keeps the Vlans that were obtained from the VTP server.
All that information is tied together in the vlan.dat file so indeed - a VTP Client can bring a network down in some situations such as 'higher revision number'.
Best Practice is to delete the vlan.dat file on any new switch being inserted into a production network.
Keep hitting those books, you are bringing up very useful topics into these forums :)
Here is some output from an isolated switch:
S4#sh vtp status
VTP Version : 2
Configuration Revision : 14
Maximum VLANs supported locally : 1005
Number of existing VLANs : 14
VTP Operating Mode : Client
VTP Domain Name : NET34
Trying to create a Vlan:
S4(config)#vlan 33
VTP VLAN configuration not allowed when device is in CLIENT mode.
No other switch connected:
S4#sh int trunk
S4#
Vlans obtained from a VTP Server before rebooting:
S4#sh vlan | e unsup
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Fa0/24
Gi0/1, Gi0/2
4 VLAN0004 active
10 VLAN_10 active
40 VLAN0040 active
45 VLAN0045 active
49 VLAN0049 active
50 VLAN0050 active
59 VLAN0059 active
100 VLAN0100 active
363 VLAN0363 active
BTW, I deleted NVRAM: "startup-config" and "private-config" files and it deleted my original configuration but the Vlan information was kept intact since they are kept in Vlan.dat as I previously stated.
__
Edison.
Thanks a lot Edison!Thanks to you ,the whole mystery is solved .
Sarah. How to you delete the vlan.dat file?
It depends on the switch as to where the vlan.dat file lives but on most switches
delete flash:vlan.dat
do a "sh flash" first to check the vlan.dat file is in flash.
Jon
Jon,
Correct me if im wrong, but doesn't delete just mark the file for deletion? to actually remove the file permanently you have to use the 'erase' option?
D
Darren
It does vary from switch to switch ie. the 4500/6500 switches use the erase command but with the fixed switches ie. 29xx/35xx/37xx the delete has usually worked for me. I'll boot up a 3550 tomorrow and check :-)
Jon
Jon,
I agree :) does vary maybe its just what I have been using of late :)
