Switch is rebooting automatically
jeamitgaur87
We have a stack of two switches WS-C2960X-24PS-L  and we are facing issue of auto reboot .  We have checked same software version and same image is running on both switch .
11 Replies 11
Leo Laohoo
Post the complete output to the following commands:
sh version
sh log on uptime detail
sh env all
dir flash1:
dir flash2:
Thanks for your reply please find below logs :-
Sh Version
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:3C:10:84:7B:80
Motherboard assembly number : 73-16694-06
Power supply part number : 341-0528-02
Motherboard serial number : FOC2150073E
Power supply serial number : DCC214198TR
Model revision number : S0
Motherboard revision number : C0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC214943PW
System serial number : FCW2151B6NF
Top Assembly Part Number : 68-100472-03
Top Assembly Revision Number : G0
Version ID : V05
CLEI Code Number : CMMLR00ARE
Daughterboard revision number : B0
Hardware Board Revision Number : 0x19
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
2 28 WS-C2960X-24PS-L 15.2(2)E7 C2960X-UNIVERSALK9-M
Switch 02
Switch Uptime : 23 hours, 54 minutes
Base ethernet MAC Address : 00:3C:10:84:B9:80
Motherboard serial number : FOC21500600
Power supply serial number : LIT21445FY5
Daughterboard serial number : FOC2149433K
System serial number : FCW2151B6QT
Top assembly part number : 68-100472-03
Top assembly revision number : G0
Version ID : V05
Sh log on uptime
UPTIME SUMMARY INFORMATION
First customer power on : 12/23/2017 15:16:15
Total uptime : 0 years 16 weeks 2 days 1 hours 15 minutes
Total downtime : 0 years 23 weeks 0 days 9 hours 9 minutes
Number of resets : 31
Number of slot changes : 0
Current reset reason : 0x0
Current reset timestamp : 05/07/2020 20:10:15
Current slot : 1
Current uptime : 0 years 0 weeks 0 days 0 hours 0 minutes
Reset | |
Reason | Count |
No historical data to display
UPTIME CONTINUOUS INFORMATION
Time Stamp | Reset | Uptime
MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes
12/23/2017 15:16:15 0x0 0 0 0 0 0
04/27/2018 11:57:56 0x0 0 0 0 0 0
05/31/2018 17:33:49 0x0 0 0 0 0 0
06/01/2018 13:21:47 0x0 0 0 0 0 15
06/11/2018 15:25:08 0x0 0 1 3 1 0
07/02/2018 12:57:28 0x0 0 2 6 20 0
07/02/2018 13:13:10 0x0 0 0 0 0 5
07/02/2018 13:28:06 0x0 0 0 0 0 0
07/02/2018 14:52:59 0x0 0 0 0 0 55
07/19/2018 20:01:59 0x0 0 2 3 4 0
07/20/2018 00:01:46 0x0 0 0 0 3 0
07/26/2018 14:15:08 0x0 0 0 6 13 0
08/06/2018 13:01:49 0x0 0 1 3 22 0
08/08/2018 23:07:07 0x0 0 0 2 4 0
08/12/2018 11:05:07 0x0 0 0 3 11 0
08/12/2018 22:33:11 0x0 0 0 0 10 0
08/17/2018 04:24:29 0x0 0 0 4 5 0
08/22/2018 04:14:21 0x0 0 0 4 23 0
08/23/2018 14:43:14 0x0 0 0 1 10 0
08/26/2018 05:45:03 0x0 0 0 2 14 0
08/28/2018 12:09:01 0x0 0 0 2 6 0
08/30/2018 11:19:46 0x0 0 0 1 22 0
09/03/2018 09:00:38 0x0 0 0 3 21 0
09/07/2018 09:15:08 0x0 0 0 4 0 0
09/08/2018 07:21:22 0x0 0 0 0 19 0
09/12/2018 23:26:10 0x0 0 0 4 11 0
09/14/2018 08:30:23 0x0 0 0 1 8 0
09/16/2018 14:53:11 0x0 0 0 2 6 0
09/17/2018 09:16:36 0x0 0 0 0 18 0
09/21/2018 03:14:19 0x0 0 0 3 16 0
09/25/2018 01:40:51 0x0 0 0 3 21 0
Directory of flash:/
3 -rwx 34 Apr 27 2018 11:56:12 +00:00 pnp-tech-time
4 -rwx 11178 Apr 27 2018 11:56:14 +00:00 pnp-tech-discovery-summary
5 -rwx 976 May 7 2020 20:05:12 +00:00 vlan.dat
6 -rwx 42892 Apr 2 2020 05:17:58 +00:00 config.text
7 drwx 512 Dec 23 2017 08:25:34 +00:00 c2960x-universalk9-mz.152-2.E7
672 drwx 512 Dec 23 2017 08:25:35 +00:00 dc_profile_dir
675 -rwx 4120 May 7 2020 20:05:17 +00:00 multiple-fs
674 -rwx 7325 Apr 2 2020 05:17:58 +00:00 private-config.text
122185728 bytes total (94973440 bytes free)
eff-e-rca-sw-as21#dir flash2:
Directory of flash2:/
2 -rwx 976 May 7 2020 20:05:20 +00:00 vlan.dat
3 -rwx 34 Dec 23 2017 16:30:28 +00:00 pnp-tech-time
4 -rwx 11112 Dec 23 2017 16:30:29 +00:00 pnp-tech-discovery-summary
5 -rwx 42892 Apr 2 2020 05:18:02 +00:00 config.text
6 -rwx 7325 Apr 2 2020 05:18:03 +00:00 private-config.text
7 drwx 512 Dec 23 2017 08:23:53 +00:00 c2960x-universalk9-mz.152-2.E7
672 drwx 512 Dec 23 2017 08:23:54 +00:00 dc_profile_dir
674 -rwx 41461 Feb 20 2019 11:38:02 +00:00 config.text.backup
675 -rwx 3549 Feb 20 2019 11:38:02 +00:00 private-config.text.backup
Martin L
is it possible one of switches overheats and reboots? are there any High temps or fan failures ?
thanks for your reply please find logs
FAN is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 39 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 58 Degree Celsius
Red Threshold : 68 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1 Built-in Good
2 Built-in Good
SW Status RPS Name RPS Serial# RPS Port#
1 <> <>
2 <> <>
I don't see any bug associated with this version and no crash file on flash. I only see some security vulnerability issues (see link) but that should not cause the switches to reboot. You may want open a ticket with TAC and send them these outputs, so they can analyze them. They most likely recommend an upgrade specially since this version is 3 years old.
https://software.cisco.com/download/advisories?fileName=c2960x-universalk9-mz.152-2.E7.bin
Thanks Reza for your help and time .
We have already opened a tac case and currently we are planning to change stack cables as per advised by tac person.
They have not advised to upgrade the IOS yet .
Is there an issue with stacking cable or stacking ports? What is the output of sh switch stack-ring?
Stack Ring Speed : 20G
Stack Ring Configuration: Full
Stack Ring Protocol : FlexStack
Hello Reza ,
What is the current IOS for C2960x.
Amit Gaur
Reset reason means the stack lost power.
Base on the output of the "sh log on uptime detail", it is showing the active stack has been losing power very regularly.
Flash does not contain any evidence of firmware failure.
The outputs supplied are all pointing to power issue as the cause of the problem.
As per customer UPS has changed at site and other switches are working fine no power supply loss .
