Switch LED
ciscousernow
Visitor
Does anyone what this light on the E means
9 Replies 9
ciscousernow
Visitor
Stack cables are all ok and show environment is all ok
@ciscousernowIf the stack cables are fine and show environment reports no issues, the orange 'E' light is likely a false alarm or software glitch. Rebooting the switch usually clears it....
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
@Enes Simnica We rebooted the switch and it is still there
  - @ciscousernow   If you reboot the switch also check the logs immediately after rebooting , and look for problem
                                indicators
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
  - @ciscousernow    Also check the output of show  environment all , if not yet done.
                                 Look at the back and  inspect the status leds of the power supplies.
                                 Use these commands too :
                                       show env all
                                            show alarm
                                            show system status
                                            show power detail
                                            show interface status
                                            show facility-alarm status
                            (not all commands may be applicable or available)
   M.
ciscousernow
Visitor
all are clear
ciscousernow
Visitor
ALARM CONTACT 1
Status: not asserted
Description: external alarm contact 1
Severity: minor
Trigger: closed
ALARM CONTACT 2
Description: external alarm contact 2
Severity: minor
Trigger: closed
ALARM CONTACT 3
Description: external alarm contact 3
Severity: minor
Trigger: closed
ALARM CONTACT 4
Description: external alarm contact 4
Severity: minor
Trigger: closed
Switch: 2
ALARM CONTACT 1
Severity: minor
Trigger: closed
ALARM CONTACT 2
Severity: minor
Trigger: closed
ALARM CONTACT 3
Severity: minor
Trigger: closed
ALARM CONTACT 4
Severity: minor
Trigger: closed
Switch: 3
ALARM CONTACT 1
Severity: minor
Trigger: closed
ALARM CONTACT 2
Severity: minor
Trigger: closed
ALARM CONTACT 3
Severity: minor
Trigger: closed
ALARM CONTACT 4
Severity: minor
Trigger: closed
Switch: 4
ALARM CONTACT 1
Severity: minor
Trigger: closed
ALARM CONTACT 2
Severity: minor
Trigger: closed
ALARM CONTACT 3
Severity: minor
Trigger: closed
ALARM CONTACT 4
Severity: minor
Trigger: closed
Switch 1: SYSTEM TEMPERATURE is OK
System Heatink-1 Temperature Value: 48 C
Temperature State: GREEN
Yellow Threshold : 80 C
Red Threshold : 96 C
System Heatink-2 Temperature Value: 50 C
System Heatink-3 Temperature Value: 51 C
System Heatink-4 Temperature Value: 44 C
Hotspot Temperature Value: 54 C
Yellow Threshold : 105 C
Red Threshold : 125 C
Switch 2: SYSTEM TEMPERATURE is OK
System Heatink-1 Temperature Value: 49 C
System Heatink-2 Temperature Value: 53 C
System Heatink-3 Temperature Value: 54 C
System Heatink-4 Temperature Value: 47 C
Hotspot Temperature Value: 58 C
Switch 3: SYSTEM TEMPERATURE is OK
System Heatink-1 Temperature Value: 51 C
System Heatink-2 Temperature Value: 47 C
System Heatink-3 Temperature Value: 47 C
Hotspot Temperature Value: 51 C
Switch 4: SYSTEM TEMPERATURE is OK
System Heatink-1 Temperature Value: 39 C
System Heatink-2 Temperature Value: 42 C
System Heatink-3 Temperature Value: 39 C
System Heatink-4 Temperature Value: 36 C
Hotspot Temperature Value: 42 C
Pwr Supply PID Serial# Status Sys Pwr Watts
Switch:1
POWER SUPPLY-1 PWR-RGD-AC-DC-H DTH290602XV OK Good 150
POWER SUPPLY-2 PWR-RGD-AC-DC-H DTH2914002E OK Good 150
Sensor Name Status Reading
PS-1 Vout Good 55000mV
PS-1 Curout Good 200mA
PS-1 Powout Good 11000mW
PS-1 Hotspot Good 49 C
PS-2 Vout Good 56000mV
PS-2 Curout Good 300mA
PS-2 Powout Good 16800mW
PS-2 Hotspot Good 50 C
Switch:2
POWER SUPPLY-1 PWR-RGD-AC-DC-H DTH2906022G OK Good 150
POWER SUPPLY-2 PWR-RGD-AC-DC-H DTH2906022Q OK Good 150
PS-1 Curout Good 300mA
PS-1 Powout Good 16500mW
PS-1 Hotspot Good 51 C
PS-2 Vout Good 55000mV
PS-2 Curout Good 200mA
PS-2 Powout Good 11000mW
PS-2 Hotspot Good 51 C
Switch:3
POWER SUPPLY-1 PWR-RGD-AC-DC-H DTH290602RA OK Good 150
POWER SUPPLY-2 PWR-RGD-AC-DC-H DTH29060228 OK Good 150
PS-1 Hotspot Good 46 C
PS-2 Powout Good 11200mW
PS-2 Hotspot Good 48 C
Switch:4
POWER SUPPLY-1 PWR-RGD-AC-DC-H DTH290602YD OK Good 150
POWER SUPPLY-2 PWR-RGD-AC-DC-H DTH290602S4 OK Good 150
PS-1 Hotspot Good 43 C
PS-2 Hotspot Good 44 C
_01#show facility-alarm status
Source Severity Description Relay Time
_01# show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
3 190.0 0.0 190.0
Interface Admin Oper Power Device Class Max
(Watts)
Gi3/0/1 auto off 0.0 n/a n/a 30.0
Gi3/0/2 auto off 0.0 n/a n/a 30.0
Gi3/0/3 auto off 0.0 n/a n/a 30.0
Gi3/0/4 auto off 0.0 n/a n/a 30.0
Gi3/0/5 auto off 0.0 n/a n/a 30.0
Gi3/0/6 auto off 0.0 n/a n/a 30.0
Gi3/0/7 auto off 0.0 n/a n/a 30.0
Gi3/0/8 auto off 0.0 n/a n/a 30.0
Gi3/0/9 auto off 0.0 n/a n/a 30.0
Gi3/0/10 auto off 0.0 n/a n/a 30.0
Gi3/0/11 auto off 0.0 n/a n/a 30.0
Gi3/0/12 auto off 0.0 n/a n/a 30.0
Gi3/0/13 auto off 0.0 n/a n/a 30.0
Gi3/0/14 auto off 0.0 n/a n/a 30.0
Gi3/0/15 auto off 0.0 n/a n/a 30.0
Gi3/0/16 auto off 0.0 n/a n/a 30.0
Gi3/0/17 auto off 0.0 n/a n/a 30.0
Gi3/0/18 auto off 0.0 n/a n/a 30.0
Gi3/0/19 auto off 0.0 n/a n/a 30.0
Gi3/0/20 auto off 0.0 n/a n/a 30.0
Gi3/0/21 auto off 0.0 n/a n/a 30.0
Gi3/0/22 auto off 0.0 n/a n/a 30.0
Gi3/0/23 auto off 0.0 n/a n/a 30.0
Gi3/0/24 auto off 0.0 n/a n/a 30.0
Totals: 0 on 0.0
_01#show switch stack-ports summary
Sw#/Port# Port Status Neighbor/Port Cable Length Link OK Link Active Sync OK #Changes to LinkOK In Loopback
1/1 OK 2/1 50cm Yes Yes Yes 1 No
1/2 OK 4/2 100cm Yes Yes Yes 1 No
2/1 OK 1/1 50cm Yes Yes Yes 1 No
2/2 OK 3/1 50cm Yes Yes Yes 1 No
3/1 OK 2/2 50cm Yes Yes Yes 1 No
3/2 OK 4/1 50cm Yes Yes Yes 1 No
4/1 OK 3/2 50cm Yes Yes Yes 1 No
4/2 OK 1/2 100cm Yes Yes Yes 1 No
_01#show switch detail
Switch/Stack Mac Address : 04e3.8701.d100 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active 04e3.8701.d100 15 V01 Ready
2 Standby f433.928c.8880 14 V02 Ready
3 Member 9ca9.b8e5.0100 13 V01 Ready
4 Member f433.928c.8300 12 V02 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 OK OK 2 4
2 OK OK 1 3
3 OK OK 2 4
4 OK OK 3 1
I am not really familiar with the IE9000 product line, but I am wondering if that is not the Express Setup Button and Setup LED?
Disclaimer: Bad answers are my own fault as they are not AI generated.
pieterh
remarkable.
your picture is different from that on the Cisco datasheet ,
on the web-page and in the video, there is only 1 LED labeld "E" in that area instead of three!
https://www.cisco.com/site/us/en/products/networking/industrial-switches/catalyst-ie9300-rugged-series/index.html
