Switch Looping when adding another Switch
Ladiesman21ch
Community Member
Can anyone help, in my case, when connecting the Unify switch from the Meraki switch, there is a loop and the internet connection is slow and sometimes in the Dashboard monitor for Meraki, there is a Misconfigured DNS and the connection is intermittent.
6 Replies 6
aleabrahao
Meraki Community All-Star
Are you connected to a trunk port? What is the STP configuration like?
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
The following is a display of the port settings from the Core Switch to the Distribution Switch.image.png
aleabrahao
And what about the STP priority? This looks like an STP problem to me. Probably when you connect this switch there is a new STP election for the network?
Philip D'Ath
Configure the ports on each switch, that are used to connect to the other switch, to be trunk ports using a native VLAN1 of 1. Make whatever other changes are required to make this config valid.
cooperolivia919
It seems to me that this loop is causing network instability and DNS errors. You can try enabling Spanning Tree Protocol on both switches and check for redundant connections. It is also worth making sure that your Meraki switch has the correct DNS settings to prevent intermittent connectivity.
joey.debra
Maybe you should mirror that downstream port to another port on the MS switch.
If the moment you connect that Unify and you see many repeated packets you are probably having a loop downstream and need to fix that first.
