Switch lost configuration... Is there any way to configure it remotely?
I have a 2960 that bounced several times over the weekend and then appears to have lost its configuration. Using CDP from the backbone switch pulls up the information below. Is there any way for me to configure the downed switch from another switch on the network? I am trying to avoid having someone from the site try to find a console cable and a suitable computer with a serial port. Any help is appreicated as we are currently down. Thank you.
C3560-Backbone#sho cdp nei d
Device ID: Switch
Entry address(es):
Platform: cisco WS-C2960CG-8TC-L,  Capabilities: Switch IGMP
Interface: GigabitEthernet0/10,  Port ID (outgoing port): GigabitEthernet0/10
Holdtime : 161 sec
Version :
Cisco IOS Software, C2960C Software (C2960c405ex-UNIVERSALK9-M), Version 12.2(55)EX2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 18-May-11 14:42 by prod_rel_team
advertisement version: 2
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010231FF0000000000002C3F38D26200FF0000
VTP Management Domain: ''
Native VLAN: 1
Duplex: full
Management address(es):
edit: Just masking some data.
InayathUlla Sharieff
Hi James,
Do you happen to see the ip address under the management address of this particular router?
If yes are u able to reach ? if yes try telnet if in case it works then you are lucky but most of the time it will not if you have lost the configuration.
Reason :
Username and password configuration might be gone
Telnet input configuration will not be there.( i.e line vty 0 4 , login, transport input telnet)
Then only way would be to console onto the router and configure the device.(Usually 90% to this type of issue would be to use console and confiugre as all the other option would be wind off).
REgards
Inayath
Hi James,
Reason :
REgards
Inayath
Hello. I provided the complete output. The management IP address is gone. I figured console access would be the case. Thanks for the reply.
