Switch management access
Brendan Marmont
Cisco 3560 configured with management VLan10 ip 10.10.10.10 can be accessed via ssh, add new management interface VLan60 ip 10.10.60.10, also can access via ssh.
When I remove interface vlan 10, I can no longer access the switch, ip 10.10.60.10 is reachable, tried transport input to include telnet, same behavior.
What am I missing here?
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560-48PS      12.2(53)SE2           C3560-IPBASEK9-M
Brendan
Is this switch meant to be acting as a L2 switch or a L3 switch ?
If it is L2 then disable ip routing and use the default gateway you have already configured
if it is L3 then remove the default gateway and add a default route using the same next hop IP eg.
ip route 0.0.0.0  0.0.0.0 10.10.60.1
Jon
5 Replies 5
Hello
When you removed this svi vlan10 is this switch running a a host or l3 router?
do you have an default-gateway configured or ip routing enabled?
res
paul
Kind Regards
Paul
Thanks Paul,
L3 and both default-gateway and ip routing enabled
ip default-gateway 10.150.60.1
interface Vlan10
 ip address 10.10.10.25 255.255.255.0
interface Vlan60
 ip address 10.150.60.25 255.255.255.0
Brendan
Brendan
What device is 10.150.60.1 ?
Can you post an output of "sh ip route" from the switch ?
Jon
Should read 10.10.60.1 is the core switch, directly connected by trunk
     10.0.0.0/24 is subnetted, 2 subnets
C       10.10.10.0 is directly connected, Vlan10
C       10.10.60.0 is directly connected, Vlan60
Brendan
Brendan
Jon
