Switch Management Login Fail
loliver
Community Member
Hello all,
I have received a SG250X to configure. However, after resetting the device to factory defaults, I cannot seem to login to the switch management application. It does not give me an error or "incorrect username/password"; it simply goes back to the login screen.
I can login to the SNA with the default "cisco" username and password but not the GUI to configure the switch. The switch is also refusing to connect via SSH or telnet as well. Any and all help is greatly appreciated.
Mark Elsen
  - Check if you can find anything in the logs related to those issues ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Blue_Bird
Hello  loliver,
Please go through the following link and see “Web Server Commands”, chapter 57 of the CLI guide: https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/250_/2_4_5/cli_guide/cli_sx250_2_4_5.pdf
Reference: https://community.cisco.com/t5/switches-small-business/sg250x-secure-web-interface-not-reachable/m-p/4473415
Best regards
******* If This Helps, Please Rate *******
