Switch model number required
sri_hem77
Community Member
i need a switch with following spec. but not able to get the proper model, can any one suggest me with the proper model
Compatibility
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX
IEEE 802.3ab 1000BASE-T
IEEE 802.3z 1000BASE-X
IEEE 802.3x full-duplex flow control
IEEE 802.3af (Power over Ethernet)
Power
Supply Power consumption: 256W maximum
100-240VAC/50-60-Hz universal input
PoE budget: 192W
Certifications
CE EN 55022, EN 61000 and EN55024
FCC Part 15 Class A
VCCI Class A
Environmental Specifications
Operating temperature: 32Á to 122Á F (0Á to 50Á C) Operating humidity: 90% maximum relative humidity, noncondensing
Network Ports
8/24 10/100 Mbps auto sensing Fast Ethernet with PoE 4 10/100/1000 Mbps auto-sensing Gigabit Ethernet switching ports (RJ-45) 2 Dual Personality SFP slots
this is required for one of the project, i can not deviate the spec. pl let me know if any one knows the proper model number with the above spec.
Rasika Nayanajith
If you google, you will find it by yourself.
Anyway it is Netgear FS728TP switch model & here is the spec.
http://www.netgear.com/images/FS728TPv2_DS_20Jan1218-5165.pdf
Pls mark this "answered" if that gives what you want.
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Rasika
sri_hem77
Community Member
