!!! WARNING: The switch is not usable !!!
fb_webuser
Level 6
Level 6
hi guys, i have 3550 switch when i boot up my switch i notice this !!! WARNING: The switch is not usable !!!... i need your advice guys and your expertise... thanks
Posted by WebUser Jessie Catalino from Cisco Support Community App
6 Replies 6
Peter Paluch
Jessie,
The switch has most probably failed a self-test during the boot (check the show post for details). Unfortunately, it is most probably damaged and will need to be replaced. There is no way around it - it has a hardware fault.
Best regards,
Peter
fb_webuser
Level 6
Level 6
thanks partner to your advice. i assume the problem is the IOS, but when i restore the IOS using ROMMON the problem still occur. this is mean the problem is the hardware or the any semiconductor inside the switch. thank you very much SIR. Peter
Jessie,
If you can boot the IOS, the show post command will tell you which part of the self-test has failed. I doubt you will be able to find anyone capable of replacing the failed chip, as there are no serviceable parts inside, but at least you will know what exactly has failed.
Best regards,
Peter
fb_webuser
Level 6
Level 6
Initializing flashfs...
flashfs[1]: 7 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 7156736
flashfs[1]: Bytes available: 8842240
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
Failed data line test (3).
addr=0x00000,sent=0x10000000 recv=0x10800000
POST: Ethernet Controller Tests : End, Status Passed
INIT: failed satellites initialization
Cisco WS-C3550-24 (PowerPC) processor (revision J0) with 65526K/8192K bytes of memory.
Processor board ID CAT0724X1EB
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 3 failed POST
POST error status : external RAM test failed
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
i notice the FAILED DATA LINE (3). and external RAM TEST FAILED. when i type the SHOW IP INT BRIEF or SHOW VLAN no fast Ethernet are available.
It's dead.
fb_webuser
Level 6
Level 6
thanks sir. leo
