Switch model recommendation
eng-a.talaat
Dear Expert,
kindly I have Cisco Core Switch 4507 24 POE 1G  + 6 SFP  , this model is End-of -sale and I have low Budget , so I need your recommendation for new L3 Core SW with 24 POE 1G  + 6 SFP fiber , thanks
gjfowler46
Hi Amr
For your replacement I like the
CISCO WS-C3850-24P-E CATALYST 3850-24P-E MANAGED L3 SWITCH - 24 POE+ ETHERNET PORTS.
It has a open bay so you can add the SFP feature.
Hope that helps!
Gary
Be aware that the 3850 only has 4x1Gb SFP modules, not 6. This is the case with the 3650 and 2960X as well. To get the SFP port density required you will need to get (2) WS-C3850-24P-E, each with the 1Gb network module and stack the two together.
Another point, you may not need the IP Services license depending on what layer 3 features are required. IP Base (WS-C3850-24P-S) may end up being sufficient for your environment, and less expensive.
I hope this is helpful.
