Switch Module Upgrade and IGMP
ihtbasitc
Hello all,
My organization is currently dealing with the EOL of the SM-X-ES3-24-P switch modules and are currently fielding the recommended SM-X-16G4M2X replacement. We are using these modules in a 4351 ISR chassis. The production unit (containing the SM-X-ES3-24-P module) runs isr4300-universalk9.16.08.02.SPA.bin as its IOS and the switch runs c3560e-universalk9-mz.152-4.E6.bin. The router I am testing with today (with the SM-X-16G4M2X module) is running isr4300-universalk9.17.03.02.SPA.bin.
The problem I am seeing is with a device which should be sending IGMP messages to the router. In our ideal configuration, which I will explain below, the IGMPs don't seem to be making it up to the router's BDI.
In the production setup (in which the multicast traffic is successfully reaching the endpoint) we use BDI 108:
interface BDI108
 description OLD_BDI
 ip address 172.16.0.1 255.255.255.0
 ip nat inside
 no ip redirects
 no ip proxy-arp
 zone-member security Z_ZONE
 ip verify unicast source reachable-via rx 101
 ip nat inside
 ip pim sparse-dense-mode
 no ip directed broadcast
 ip igmp mroute-proxy Loopback0
 ip wccp 61 redirect in
 ip wccp 63 redirect in
 ip wccp 65 redirect in
 no cdp enable
This connects to the VLAN on the switch via the internal ethernet interface:
interface Ethernet-Internal1/0/0
 description To Switch via Router backplane
 no negotiation auto
 no mop enabled
 no mop sysid
 service instance 108 ethernet
  description OLD_VLAN
  encapsulation dot1q 108
  rewrite ingress tag pop 1 symmetric
  bridge-domain 108
This is the interface that the client connects to on the switch:
interface GigabitEthernet0/8
 description OLD_USER
 switchport access vlan 108
 switchport mode access
 switchport nonegotiate
 spanning-tree portfast
 spanning-tree bpdufilter enable
 spanning-tree bpduguard enable
 spanning-tree guard root
In this configuration, the command "show ip igmp group" entered on the router shows the IGMPs reaching the BDI and subscribing to 225.10.2.22.
The new switch module does not run a separate instance of IOS, as the old one does. This means there is no internal ethernet interface and we need to bridge the gap between the switch and the router another way. Our ideal option is to use an SVI with a service instance to do what the internal ethernet interface was doing. This is what we are fielding (no change to the configuration of the access port):
interface BDI108
 description NEW_BDI
 no ip redirects
 no ip proxy-arp
 ip nat inside
 no cdp enable
interface Vlan108
 description NEW_SVI
 no ip address
 no ip redirects
 no ip proxy-arp
  bridge-domain 108
The setup above passes unicast traffic successfully, but introduces a problem with multicast that is stumping me. When I enter show ip igmp group on the router, I don't see any IGMPs making it from the host to the router. Alternatively, this second less-ideal option does recieve the IGMP (again no change to the access port):
interface Vlan108
 description NEW_SVI
 no ip redirects
 no ip proxy-arp
 ip nat inside
When I switch from the BDI-based config to the SVI-only config, the router immediately picks up the IGMPs, so I know that the client is sending them. Should the solution with the service instance applied to the SVI work? Is there any configuration I'm missing here? As I see it, I'm thinking this should work.
Let me know if I can provide further clarification.
0 Replies 0
