Switch Mounting
KristopherOhlsson5963
Community Member
Hi all, I work for a large company, and we get our switches out of a warehouse, already our of the box, I'm looking for the screw template that comes with 3560/2960's that'll enable us to mount under some tables, any help will be great, thanks in advance.
Reza Sharifi
What comes with these switches is the ear-mount and the screws which are used to mount the switch in a rack. So, you can't mount these switches under desks with the mounts they come with. You need to use a different solution for desks.
rm760
Level 4
Level 4
I have used the mount described in the link below under tables.  Please note I did mount the Cisco provided mounting ears with the tabs towards the middle of the switch to create a better balance.  I also set recessed the under desk mount to keep the patch cord connections away from the knees of those seated at the table.
https://www.discount-low-voltage.com/Connectivity/The-Instant-Rack-Specialty-Rack-Mount-Brackets
