Switch not Sending out Broadcasts? GNS3 Emulation
ZoellerG
Hi Everyone,
i'm currently facing a really strange problem, i'm running a simulation in GNS3 with the following Topology
The Switch to which everything is connecting (N301SWC01) is the coreswitch, the 2 other Switches that it's connecting to are the access switches (collapsed core),  this is where the strange things start happening, theres vlan 104 in which the access switches have an ip (10.1.104.xx/24), and every vlan is allowed on the trunk port, however both of the switches are not sending out arp broadcasts in the same vlan, basically every client thats requesting a arp reply, gets deadzoned, to ports to which the clients are connected are access ports in vlan 10.
When i connect the pc3 to the core switch everything is working.
There are a couple of things i have configured on the access layer
  • ARP Inspection (validation of src-mac)
  • DHCP Snooping (database is lying on the ftp server)
  • ip source guard
Is there perhaps something im missing here?
If you need any running configs / Infos feel free to message here.
Greetings
Georg György Zoeller
2 Accepted Solutions
balaji.bandi
post below output from all the switches :
show run
show vlan
show ip interface brief
show ip route
show ip arp
BB
ZoellerG
after a bit more testing i have found out that the problem is caused by ip source guard, apparently the source guard code in this version of iosvl2 is a bit buggy.
Thanks for trying to help!
balaji.bandi
show run
show vlan
show ip route
show ip arp
BB
Heres the Output
https://pastebin.com/kruPs27z - n301swa01711
https://pastebin.com/e1aAbjtZ - N301swa01511
i dont think i need the configuration of the coreswitch since arp seems to work properly on it, atleas my accesport in vlan 10 seems to be doing broadcasting the way it should.
all of the vlans are being learned via vtp
Thanks in advance.
ZoellerG
