Switch number in VSS
rhub
Hi all,
After having some troubles with VSL, I finally had to convert one 6509-E chassis back to a standalone chassis. Now I would like to bring it back into the VSS configration.
Whenever I try to convert it to a virtual system (switch convert mode virtual) I get the msg %Please configure local switch number first". After doing so by entering "switch set switch_num 1 local" I still get the same msg.
Has anyone faced the same situation before ?
Any hints or tipps are very much appreciated.
Thanks and best regards
Roman
2 Accepted Solutions
Leo Laohoo
Duplicate post #2.
graham smart
VSS configuration should be like so..
6500-1
conf t
switch virtual domain 100
switch 1
switch 1 priority 100
switch 2 priority 110
exit
6500-2
conf t
switch 2
exit
Not sure where the switch set switch_num bits come from?
Hope this helps
-Graham
Please note: My comments are simply suggestions. I cannot be held liable for any loss of data, life or marbles due to following my instructions.
Got a website? Need some live chat software?
10 Replies 10
Leo Laohoo
Duplicate post #2.
graham smart
6500-1
conf t
switch 1
exit
6500-2
conf t
switch 2
exit
Hope this helps
-Graham
hi graham,
unfortunately this is exactly the config i've done. when i try to configure po 1 as vsl-link (switch virtual link 1) i get the same msg "%please configure local switch number first".
I assume a "show switch virtual" command gives no output as yet..?
Seems very strange.
-Graham
Hi Graham, i finally solved the problem, which indeed was a strange behaviour. First I checked the switch_id in rommon with the command "switch read switch_num local" - the number was correct configured as "1".
I changed this value to "2", which is basically wrong, since the other VSS component already is configured with the same switch number.
After that, I was able to configure Po 1 as VSL channel. Then I changed the switch number back to "1" and finally was able to do the "switch convert mode virtual" and here we go.
Many thanks for replying to my post.
Best regards
Roman
Wow madness.
VSS can be a touchy bit of tech.
Ive spent many hours in boot-loops and rommon before finally getting a working solution.
But glad its working It really is lovely when working correctly!
-G
-Graham
Yes, so did I and indeed I like VSS since it came out first and it works just great
Roman
alex.net
Actually this is a possible the explanation:
Once you have assigned the switch number just exit, DO NOT ASSIGN SWITCH PRIORITY YET! If you assign switch priority after assigning the number you will encounter virtual switch link configuration problem that looks like this %Please configure local switch number first under the port-channel interface.
https://cyruslab.net/2012/12/21/cisco-systems-virtual-switching-system/
Sandesh Sawant
Very Basic Configuration :: This should work as expected.
VSS(config)#switch virtual domain 100
VSS(config-vs-domain)#switch 1
VSS(config-vs-domain)# exit
VSS(config)#interface port-channel 1
VSS(config-if)#switch virtual link 1
VSS(config-if)#interface TenG 5/4
VSS(config-if)#channel-group 1 mode on
VSS(config-if)#interface TenG 5/5
VSS(config-if)#end
VSS#switch set switch_num 1 local
VSS#switch convert mode virtual
Thanks for the update. It's really helpful.
