Switch performance, line rate vs non blocking vs wire speed
ngtransge
I am interesting what is difference between following terms, from cisco switch data sheets?
  • line rate
  • non-blocking
  • wire speed
Thank you,
San
Reza Sharifi
here is good post you can look at:
https://supportforums.cisco.com/discussion/10430571/switches-forwarding-bandwidth-vs-wire-speed
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In brief, for switches, line-rate or wire-speed basically means the device has the forwarding (PPS) capacity to support all ports, concurrently, at 100% capacity (even at minimum packet sizes).  Non-blocking often means the switch's internal bandwidth has sufficient capacity to carry all the port bandwidths, concurrently, at full capacity.  Non-blocking could also mean the switch's architecture isn't prone to head-of-line blocking.
