OTV and IPSec
mohamed louhab
Hi ,
I want to encrypt the traffic between my DCIs . I use OTV as Technoligie to interconnect two DCI.
I want to know how to enable OTV Over Ipsec ??
I did the standard configuration but it didn't work
thank you
pratheesh.venu
Mohamed,
I also have a similar requirement and appreciate if you can share the details about the solution that you have considered. Thank You.
Pratheesh
