Switch port bandwidth problem
branfarm1
Level 8
Level 8
Hi there,
I have a Cisco 3020 bladeswitch that is only reporting interface bandwidth of 10000Kbit when the link is actually a gigabit interface:
GigabitEthernet0/9 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001b.0c06.4909 (bia 001b.0c06.4909)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 1/255, rxload 21/255
Keepalive set (10 sec)
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:29:44
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 844000 bits/sec, 54 packets/sec
5 minute output rate 13000 bits/sec, 37 packets/sec
179197 packets input, 243202451 bytes, 0 no buffer
Received 42 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
134878 packets output, 9565053 bytes, 0 underruns
Here's the interface configuration:
Current configuration : 60 bytes
interface GigabitEthernet0/9
spanning-tree portfast
end
I've tried having both sides as Auto, and both sides set manually, with no luck. Has anyone seen this issue before? Any ideas?
Thanks in advance
garytayl
Level 7
Level 7
If you are running 12.2(25)SEF2, There is an internal cosmetic bug for that. It is first fixed in 12.2(35)SE.
5 Replies 5
garytayl
Level 7
Level 7
Thanks for the reply. So, being cosmetic, does that mean it doesn't actually affect the speed of the interface?
That is correct, it is only cosmetic and won't affect the actual speed of the interface. If you use monitoring tools then you will have problems with the reports and interfaces capabilities...
Please can you post the bug details here for ref ? I cannot find any reference in release notes or bug toolkit etc.
You won't be able to find it because it is an internal bug and pretty much all we can see is:
CBS3020: show int CMD shows incorrect BW, DLY info on internal ports
1st Found-In
12.2(25)SEF2
Fixed-In
12.2(35)SE
