Switch port configuration for virtualization
notoftheearth
I have a switch which will connect to a physical server used in virtualization.  This means that virtual machines with IP addresses on multiple subnets will be sending layer 2 frames to this switch.  However, in attempting to minimize the number of NICs on this server there is a question.   If there were only one NIC in this physical server connected to one port on the physical switch - is it possible to have one port on the physical switch handle frames which originate from all VMs running on the physical server - when these VMs have IPs on different subnets?  Or does each separate logical subnet require a separate switch port to handle its frames and a separate physical NIC on the server used for virtualization?
Thanks for your input
Bert Gevers
with recent devices, you should be able to configure one physical link between the switch and the server as a trunk.
Trunking is a way to carry traffic from several VLANs over a       point-to-point link between the two devices.
You can then map each virtual machine/separate subnet to a different vlan on the trunk keeping the traffic logically separated.
HTH,
Bert
Bert Gevers
HTH,
Bert
