switch port configuration
yann.boulet
i need to configure an isolated switch with default configuration with a dedicated network on my catalyst network core with vlans, this dedicated switch is directly connected to my pix firewall interface.
first i only need to pass through my catalyst core network so i prepared a cable to the firewall interface and another cable to replace the one on the isolated switch, what do i need to do on the 2 interfaces of my core switch ?
switch mode access ??
thank you
bvsnarayana03
Level 5
Level 5
if its isolated, then i understand it'll have its own vlans & requires no communication with any other device on network.
Then you may create a vlan on core, assign 1 port to this vlan & connect your isolated network switch to this vlan port. Yes, it'll be access port & doesnt need to be trunked.
thank you for the reply but do i need to configure same vlan ID on the isolated switch where interfaces are connected to the core switch ?
Yes you have to create this vlan on the isolated switch & add the port conecting core to this vlan.
ok thanks a lot so my port configuration should be the same for both switches and like that :
interface GigabitEthernet3/2
switchport access vlan 212
switchport mode access
