Switch port count summary per vlan
Yang Xia
Dear NetPros,
For a 6509 switch with 7 48 port line cards, is there a quick way to count how many switch ports are belonged to which vlan? Counting them line by line from "show vlan" result is kind of too slow.
Yang
Edison Ortiz
Try the following command:
show run | i switchport access vlan #
Replace the # with the vlan number and parse the output onto Excel. On Excel, the row count should give you the total switchports on that Vlan.
HTH,
__
Edison.
Edison Ortiz
HTH,
__
Edison.
Thanks, that works!
sh vlan brief
vhasagbrownjr
sh run | count vlan 141
