09-21-2016 02:04 AM - edited 03-08-2019 07:31 AM
Most of the switch ports(which is configured for data and voice together) goes up & down after every few seconds.
031695: Sep 21 10:56:04.513 MEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12, changed state to down
031696: Sep 21 10:56:06.518 MEST: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/12, changed state to up
Here si the config:
interface GigabitEthernet1/0/12
switchport access vlan 21
switchport trunk native vlan 21
switchport voice vlan 221
switchport priority extend trust
spanning-tree portfast trunk
Can anyone check and let me know the issue.
09-21-2016 05:25 AM
hi,
what device is connected on port Gi1/0/12?
it seems you have both access and trunk port configured in it.
09-21-2016 10:47 PM
Alcatel Telephone and then a Workstation.
09-22-2016 03:45 AM
I believe that when you use a VOIP phone connected to the switch, and use that phone to connect to the workstation, you can use the voice vlan command. Is it specifically stated in Cisco site that when using Alcatel VOIP phone, you need to configure both voice vlan and trunking at the same time on the switch port?
