Switch Port Problem
prakalaathan
Community Member
Hi All,
I'm getting following error.
783247: Jul  3 15:28:12.388 PDT: %ILPOWER-7-DETECT: Interface Gi2/15: Power Device detected: IEEE PD
783248: Jul  3 15:30:14.905 PDT: %ILPOWER-7-DETECT: Interface Gi2/15: Power Device detected: IEEE PD
783249: Jul  3 15:31:43.626 PDT: %ILPOWER-7-DETECT: Interface Gi2/15: Power Device detected: IEEE PD
783250: Jul  3 15:31:44.026 PDT: %C6K_POWER-SP-1-PD_HW_FAULTY: The device connected to port 2/15 has a hardware problem. Power is turned off on the port
Please help me to find out this errors..
Thanks.,
Prakalathan
Hi Prakalathan,
I suggest you check the device connected to port Power over Ethernet (PoE) Gi2/15 of its Catalyst 6K. It is likely that the device requires a greater supply of power to the port may offer. Check the device's specifications and your port.
Reference: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/troubleshooting/g_power_over_ethernet.html#wp1018018
(Session: Surge-In Current.)
Luciane de Medeiros
