Switch port problems 2960
Areyouserious
Level 2
Level 2
Hi all.
Had some very strange issues this evening.
I have a 2960 Switch that only seems to like certain devices being plugged into it.
For example, I tried plugging two different laptops into a few different ports, namely port 4, 5, 6,  but no link is established.  Link reports that ports are down via console SSH.    Both laptops report that the Ethernet is unplugged.
Yet.....if I plug a Cisco phone into these ports, or a WAP,  or trunk link, the ports work fine.
One of the laptops was working fine this afternoon, then all of a sudden the switch appeared to reject it, as well as the second laptop that we used to test/troubleshoot it.
service password-encryption
hostname XXXXXXXXXX
boot-start-marker
boot-end-marker
username XXXXXXX privilege 15 secret 5 XXXXXXXXX
no aaa new-model
system mtu routing 1500
vtp mode off
ip domain-name XXXXXX
spanning-tree mode pvst
no spanning-tree vlan 7
vlan internal allocation policy ascending
vlan 2-3,5-8
interface FastEthernet0/1
switchport access vlan 2
no cdp enable
spanning-tree portfast
spanning-tree bpduguard enable
spanning-tree guard root
interface FastEthernet0/2
switchport access vlan 6
no cdp enable
interface FastEthernet0/3
switchport access vlan 3
no cdp enable
interface FastEthernet0/4
no cdp enable
interface FastEthernet0/5
no cdp enable
interface FastEthernet0/6
no cdp enable
interface FastEthernet0/7
switchport access vlan 7
no cdp enable
interface FastEthernet0/8
switchport access vlan 8
no cdp enable
interface GigabitEthernet0/1
switchport mode trunk
no cdp enable
interface Vlan1
ip address 10.1.1.78 255.255.255.0
no ip route-cache
interface Vlan7
no ip address
ip default-gateway 10.1.1.5
no ip http server
no ip http secure-server
no cdp run
vstack
line con 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login
end
8 Replies 8
Reza Sharifi
Can you hard set the speed and duplex for the ports that are not functioning correctly and test again?
Georg Pauwen
also, try and remove:
from the ports, and check if that makes a difference.
This problem resolved it's self when I arrived at this site to fix the problem.
I'm rather confident it's being hacked.
We have had quite alot of people playing games on our system, possibly some kid down the road with a long range WiFi antenna.
Another problem is they keep hacking a security CCTV system attached to this switch on vlan 3.
I've tried adding soo many security ACL's on the 2811 router connected to it to make sure that the only IP that can remotely access the cameras is from our main site over our site to site vpn.  Some how they keep gaining access to it.
Hello
Try reapplying vlan 6 even when ports 4/5/6 are already assigned to it.
What is the reason spanning-tree is disabled for vlan 7
Suggest:
conf t
vlan 6
exit
no spanning-tree bpduguard enable
no spanning-tree guard root
interface Vlan1
ip route-cache
no interface Vlan7
no vstack ( only is your not using this feature)
Kind Regards
Paul
Hi Paul,
VLAN7  is assigned to a port that heads to a WAP.
This is the only switch being used as router on a stick, GIG0/1 goes to the router as the trunk link.
I'm confident now that our switch is being hacked.  Possibly through backwards through our WAP.
This is the version running
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 04-Oct-16 03:37 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Switch1 uptime is 6 hours, 46 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.151-4.M12a.bin"
Last reload type: Normal Reload
I had a look on the Cisco firmware downloads and apparently from what I can tell, this is the latest firmware version.
Despite multiple security and CVE releases stating that new versions had been released late this year.
Stojmenovic
Could you please share the output of command show port-security of interface that you tried to connect your laptop?
not sure how to do it for a specific port.....
Secure Port MaxSecureAddr CurrentAddr SecurityViolation Security Action
(Count) (Count) (Count)
Total Addresses in System (excluding one mac per port) : 0
Max Addresses limit in System (excluding one mac per port) : 8192
