3650 Auto QoS Question
mkazam001
Level 3
Level 3
Would like a response from members who've implemented QoS please.
I understand that by default, all ports will trust dscp markings on this switch.
How would you configure auto qos on a 3650 switch stack so that VoIP traffic is prioritised on access ports & uplinks?
What are the verification commands?
Regards, mk
5 Replies 5
balaji.bandi
Check the auto QOS Configuration :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/qos/configuration_guide/b_qos_3se_3650_cg/b_qos_3se_3650_cg_chapter_011.html
Look at te Monitoring section for monitoring and verify.
BB
Thanks Balaji, I'd already seen the documentation, I was after actual port configs.
Regards, mk
You can run autoqos command as below inside interface :
auto qos voip cisco-phone
auto qos voip trust
Monitor
 show auto qos interface g 1/1 <-- example use the interface
BB
Hello
Regards, mk
conf t
int x/x
description cisco Voip device
auto qos voip cisco-phone trust <------------------Trusting the Cisco phone qos settings
int x/x
description cisco Video telepresence device
auto qos video cts  <-------------Trusting Cisco  video conferencing qos settings
int x/x
description switch trunk uplink
auto qos trust <-ONLY on physical interfaces , if portchannel apply on their physical interfaces not on logical interface
Kind Regards
Paul
thank you both, i will add this to my already copious amounts of notes on QoS.
im hoping it will fall into place once i test on the switches.
will rate both as helpful :)
regards, mk
