switch port security
gopinath.krishna
Community Member
i have planned to do this
1.enable switch port security on the switch ports and allow 3 mac address
2.statically add the mac address of the pc & voip phone through switch port security mac address command
so now two mac address are added statically and third mac will be learned dynamically.
can we use the aging time only for the dynamically learned mac addressess?
5 Replies 5
rajinikanth
Level 6
Level 6
Hi Krish,
Default settings for switchport port security is
Aging : Disabled
Aging type : Absolute
Static Aging : Disabled
Since static aging is disabled you can set the aging for dynamic learned MAC using
the below command
Switch(config-if)# switchport port-security
[ aging {static | time aging_time | type
{absolute | inactivity} ]
Do not use static keyword in above syntax which enables aging for statically configured secure addresses on the port.
Raj
Hi Raj,
thanks for those information.
i think configuring aging time is not possible if i use switc port security with sticky options.is that correct
one more query
I have created two vlan 10 & 20
i wanted to use 20 for voice traffic...
If i configure the interface to which a voip phone and a pc gets connected with following will there will any problem
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# switchport access vlan 10
Switch(config-if)# switchport voice vlan 20
Switch(config-if)# switchport port-security maximum 2
Switch(config-if)# switchport port-security mac-address 0000.02000.0004 vlan voice
Switch(config-if)# switchport port-security mac-address 0001.00002.0003 vlan access
my question is whether avove is an valid config
Yes it is valid
Narayan
Per-VLAN configuration is supported only on trunks.
Since you have configured the interface has access port you can not use the static mac-address statement with vlan vland_id.
So its a invalid config.
chk this link
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/port_sec.html#wp1053357
Raj
Well this is an interesting thing to test
i have read in some cisco documents that when you enable a voice vlan, it dynamically creates a trunk to pass the 2 vlans
So will this be valid in the above case
Narayan
