Switch Port takes too much time from Amber to Green
markkwong
Does anybody know why if i reboot or unplug-plug the ethernet cable, it takes around 30 seconds to get from Amber to Green?  Is there any way to make it almost instantanious?
The application that i'm using cannot wait for that long, and it fails it's tests while waiting.
Mark
   It is a forward-delay time of spanning tree. If you want to skip states of spanning tree, just try this.
Switch#conf term
Switch(conf)#interface AAAA
Switch(conf-if)#spanning-tree portfast
   AAAA is an interface connected to the server.
HTH,
Toshi
