switch problem
khuleni2011
help!! switch 2950 all light are blinking when i turn it on
10 Replies 10
Mark Elsen
 - Possible fatal hardware problem , do you still get any output on the console ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i dont get any out output sir
Jitendra Kumar
This is also a case.
windows cluster (network load balanced) that was sending out multicast igmp packets.
change the mode to unicast, and switched the value for MaskSourceMAC from 1 to 0 in the registry on the windows servers that were load balanced.
Jitendra
will try that
Jitendra Kumar
If Nothing is written on the console.
 Time for you to contact Cisco TAC and get the RMA
Jitendra
ashish.kushwaha
it is blinking orange and green
Ashish K
***Please Rate Helpful Responses***
Have you connected the console cable with the switch??
Any output on the console??
Jitendra
no output sir
If you have support contract raise a RMA for them
Jitendra
yes
