Switch problm
vabzplanet
i have a 3750 Giga speed switch,
each port is capable of 1 gb port
but when i do inventory using ciscoworks,it shows me that some ports are not functioning properly.
some ports are showing 10/100 mbps
desai.jaideep
Level 5
Level 5
What are the PCs connected to the 10/100 ports.Are the LAN cards also of 10/100 or 1GB?
Are the ports manually configured for the same?
JD
glen.grant
Unless the user nic cards are newer gig nics that is all they are going to get is either 10 or 100 meg depending on how they are setup or autonegotiate.
birthwell
If Nic and computer cards support Gig speed, check the cable standard.Is it cat5 or cat5e the one used to connect the clients.
