Switch query
jkaushik
Frequent Visitor
Frequent Visitor
Switch GS350-8DP :
If ethernet 5 and 6 connected to each others via Cat5 3mts cable?
Observed continue packet is receiving on both port form switch. Is any way to disable traffic ?
STP will block the ports once it detected the loop is there. if you disables STP, that will be give loop in switch and can introduce storms.
Good luck
KB
thanks, can you share commands to disable STP on ethernet 5 and 6 ports.
Are you planning to test looping for studying purposes? if that's the case don't test it in a production environment.
If you disabled the STP in the switch will occur loop/storm issues
Please check this link:
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350x-series-stackable-managed-switches/smb5101-configuring-stp-status-global-settings-on-the-sg350xg-and.html
KD
