Switch rebooted
I have a switch 6500 series running cat os version :
8.6(4).
It got rebooted last night and i am attaching the show loggs:
I am attaching the show tech.......
Is this a memory leak issue : As there are many holding memory....
****************** show proc mem ******************
Memory Used:  18753920
       Free:  29717792
      Total:  48471712
PID        TTY        Allocated  Freed      Holding    Process
1          -2         12283680   947136     11336544   Kernel and Idle
2          -2         0          0          0          DiskInodeRefres
3          -2         288        0          288        Flash MIB Updat
4          -2         256        0          256        PowerMgmt
5          -2         192        0          192        L2L3IntHdlr
6          -2         192        0          192        RecoveryL2L3
7          -2         0          0          0          L2L3PatchRev
8          -2         0          0          0          EobRecoveryProc
9          -2         668288     611872     56416      SynDiags
10         -2         192        0          192        GenMsgHndlr
11         -2         2250176    698880     1551296    SynConfig
12         -2         64         0          64         TempMon
13         -2         0          0          0          System_CrashInf
14         -2         3456       0          3456       IDLE_Tasks
15         2260028692 1777120    1718880    58240      show_command
16         -2         97664      0          97664      SL_TASK
17         -2         31520      15808      15712      RedundantTask
18         -2         2560       0          2560       Status Poll
19         -2         128        0          128        SWPoll64bCnt
20         0          2752       0          2752       HavailTask
21         -2         10368      0          10368      SyncTask
22         -2         224        0          224        DeviceLinkChk
23         -2         3539296    3539264    32         Earl
24         -2         16672      0          16672      TablefullTask
25         -2         929632     926528     3104       DTP_Rx
26         -2         400480     227840     172640     EthChnlRx
27         -2         0          0          0          llcSSTPFlood
28         -2         358848     127680     231168     EthChnlConfig
29         -2         4928       3072       1856       FlexlinkRx
30         -2         102560     0          102560     SecurityRx
31         -2         5696       4384       1312       ACL
32         -2         33888      3616       30272      VaclLog
33         -2         3872       3616       256        ArpInspection
34         -2         0          0          0          AclStats
35         0          0          0          0          L3Aging
36         0          212576     3136       209440     NetFlow
37         0          2702144    10368      2691776    Fib
38         -2         0          0          0          Fib_bg_task
39         -2         0          0          0          DNSResolver
40         -2         3968       3616       352        DhcpSnooping
41         0          0          0          0          Lyra Freeze Tas
42         -2         330624     330304     320        SptTimer
43         -2         330976     327552     3424       SptBpduRx
44         -2         224        0          224        SptBpduTx
45         -2         23680      2240       21440      VtpTimer
46         -2         224        0          224        ProtocolFilter
47         -2         8224       0          8224       MacMoveNotTask
48         -2         34976      34944      32         telnetd
49         -2         32         0          32         connecthelper
50         -2         32         0          32         ssh_flush
51         -2         32         0          32         sshd
52         -2         213152     212384     768        ssh_key
53         -2         32         0          32         tftpd
54         -2         96         0          96         sntp_recd
55         -2         32         0          32         sntp_xmitd
56         -2         1409440    1409280    160        ProtocolTimer
57         -2         128        0          128        ciscoRmonTimer
58         -2         128        0          128        ciscoUsrHistory
59         -2         160        0          160        rmonMediaIndep
60         -2         15808      15808      0          SnmpTraps
61         -2         0          0          0          memPoolMain
62         -2         1214496    1214464    32         Acct Send Bkg
63         -2         216064     216032     32         StopRecordAcctT
64         -2         128        0          128        l2t_server
65         -2         8812960    8812544    416        Debug Port Coun
66         -2         79072      79040      32         SysLogTask
67         -2         160        0          160        pinggateA
68         -2         13136480   13125440   11040      cdpd
69         -2         7059104    7058880    224        cdpdtimer
70         -2         41472      7936       33536      RouterConfig
71         -2         128        0          128        RMON AlarmTimer
72         -2         8288       0          8288       Authenticator_S
73         -2         32         0          32         Backend_SM
74         -2         224        0          224        dot1x_rx
75         -2         256        0          256        Dot1x_Dhcp
76         -2         224        0          224        GrpManager
77         -2         32         0          32         Backend_Rx
78         -2         32         0          32         Radius Acct Pro
79         -2         32         0          32         RadiusTracking
80         -2         96         0          96         MacAuthProc
81         -2         160        0          160        AuthControlMgr
82         -2         224        0          224        GL2Prot_Tunnel
83         -2         0          0          0          sptTraps
84         -2         352        0          352        M-MLS_stats
85         -2         4480       64         4416       M-MLS_manager
86         -2         73280      31488      41792      QoSTask
87         -2         256        0          256        ErrDisable Time
88         -2         12416      0          12416      GBIC Process
89         -2         512        192        320        oam_tx_proc
90         -2         224        0          224        oam_rx_proc
91         -2         13681376   13681152   224        oam_monitoring_
92         0          18496      0          18496      Read Stats Task
93         0          64         0          64         QDE Task
94         0          64         0          64         BcastSuppr Task
95         -2         3072       0          3072       VlanStatsTask
96         -2         524352     0          524352     NvramMonitor
97         0          32         0          32         SFF8472
99         -2         32         0          32         HPActive
100        -2         96         0          96         HPTrapMgr
143        -2         1929952    1170208    759744     VtpRx
144        0          58336      3744       54592      Console
145        -2         1837792    1400544    437248     snmpdm
146        -2         169920     169536     384        SNMP_THREAD
147        2259982228 152864     88928      63936      telnet147
148        2260028692 94336      30400      63936      telnet148
149        2259315860 76032      12096      63936      telnet149
156        -2         61408      46272      15136      AclManager
Memory Pool Utilization
Memory Pool Type 1Min  5Min  10Min
DRAM               66%   66%   66%
FLASH              76%   76%   76%
NVRAM              60%   60%   60%
MBUF                3%    3%    3%
CLUSTER            14%   14%   14%
MALLOC             38%   38%   38%
Leo Laohoo
I'm no expert with CatOS but the following lines could be suspicious:
Module 4 : WS-X6416-GBIC non-zero error counters -
PORT ASIC 1:
none.
PORT ASIC 2:
none.
PORT ASIC 3:
01B9:                        PI_MS_RX_HOLD_REG = 0058
PORT ASIC 4:
01B9:                        PI_MS_RX_HOLD_REG = 036C
Can you post or attach the filename "crashinfo_100511-002311"?
