Switch recommendations for a Branch Office
KMNRuser
Forum,
I would like to ask for recommendations on a Cisco switch model that would be ideal for a branch office.
The requirements would need to be:
Gigabit Eth user ports.
10G ports for servers
Failover of power supplies (have at least 2 pwr supplies)
Run IOS or IOSXE (in other words not exclusively managed by web gui but has local console also)
POE + capable
L3 features
I would ask for recommendations for
offices with above 250 users..
office with less than 250 users,
and offices with less than say 25 people
Thank you in advance!
Kevin
marce1000
 - Some 'generic' starting points can be found at
             https://www.cisco.com/c/en/us/solutions/small-business/selector-tool.html
             https://www.cisco.com/c/en/us/products/switches/switch-selector.html
 M.
have a look at the Catalyst 9K series. They all have Gigabit ports and several models have 10G uplink ports.
https://www.cisco.com/c/en/us/products/switches/campus-lan-switches-access/index.html#~solutions-services
balaji.bandi
what is the budget, what are you running in HQ ?
CAt 9300 is a good choice for the branch since you looking for Layer 3 features.
If only static routing, then consider Cat 9200 has PoE and static routing support.
BB
Leo Laohoo
How 10 Gbps ports?  What physical connection, copper, fibre, DAC?
@KMNRuser wrote:
POE + capable
Be specific, 15.4wac, 30.0wac, 60.0wac or 90.0wac?
@KMNRuser wrote:
L3 features
Be specific, OSPF, RIPv1/RIPv2, EIGRP/BGP, VRF/MPLS?
Finally, what is the budget allocated for this spending spree?
