Switch Stack Question
Tahir Ali
Level 2
Level 2
Hi all,
I have a small question,
we have an nms which is getting the alarms for the stack port down from all of our 3750 stackable switches.
We havent connected or configured any stacking and dont want to, as we are using our switches without stack.
to cater this I remove the snmp-trap command
no snmp-server enable traps stackwise
But still we are getting the alarms.
Kinldy i need some solution to disable these alarms or shut the port admin down as the above command is not working and we are still getting the alarms on the NMS for the stack.
mode # WS-C3750G-24T-S
flash:c3750-ipbasek9-mz.122-53.SE1.bin
David Kosich
Level 3
Level 3
Hi Tahir,
Can you post a 'show log' from the switch in question? Are you seeing log messages on the switch about the stack ports as well?
