11-12-2021 11:24 AM - edited 11-12-2021 11:48 AM
Can a WS-C3850-48T-S and WS-C3850-24T-E be in a stack together? Just those 2 switches.
WS-C3850-48T-S
License Level: Ipbase
WS-C3850-24T-E
License Level: Ipservices
only basic IPv4 L3 switching and routing, static routes and OSPF routing (No IPv6) is actually required.
Solved! Go to Solution.
11-12-2021 04:33 PM
No possible unless the switch with IP Services license is manually downgraded to IP Base.
11-12-2021 04:33 PM
11-12-2021 10:45 PM
As also Leo noted, you want to have the same license type. So, since you need OSPF, it is better to upgrade the license for WS-C3850-48T-S to "IP Services" and then stack them. This way, if you lose a switch, you don't lose any feature set.
11-18-2021 01:06 PM
Thanks. I'll give the first person to answer the credit.
