Switch Stack
qwertys21
Level 4
Level 4
Hi All
Can I stack a WS-C3750G-48TS-S and a WS-C3750G-12S-S? And what do I use?
If I can, do i need to respecify the switches asking for stacks or do they come already stack specified?
dgoodridge
Level 3
Level 3
If both switch models support stacking (i.e they have stackwise ports) then you can stack them, even if they have differing port capacities.
You will need to use stackwise cables (0.5m usually supplied in box).
Be careful to note the usual stacking rules regarding IOS levels etc.
Hope that helps.
Doug
Amit Singh
Hi Friend,
Please go through the link below and you will get to know all the software/hardware compatibility options:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_see/configuration/guide/swstack.html#wp1189553
HTH, Please rate if it does.
-amit singh
