Switch Stacking with diffrent model switch
Tarunkumar Vyas
Level 2
Level 2
I have one ws-c3750x-24t-s model switch with stack cable.
can I make stacking ws-c3750x-24t-s with cisco 3560 switch.
Please help....
No, the 3560-series doesn't support stacking. You should order another 3750x to extend your stack.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Hi Karsten,
Cisco 3560 switch support stack, and both has same  compitibility but not able to find that both diffrent model support  stack with each other or not.
Please find link.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
no, the 3750-series is stackable while the 3560-series are standalone switches. That't their main difference. That's also documented in the Data-Sheets.
markeelen
Level 2
Level 2
Hi Tarun, the first line of the data sheet states clearly:
The Cisco® Catalyst® 3750-X and 3560-X Series Switches are an enterprise-class lines of stackable and standalone switches, respectively.
From this I would suggest that those two switches will not stack.
Cheers
Mark
