Switch Stacking
a.perriman
Community Member
We currently have a stack of 5 x 3750 switches and i want to remove switch number 3 (it has the least number of things plugged in).
Can anyone tell me what will happen to switch 4 and 5 will they be renumbered 3 and 4, and will the config automatically update this if it does?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Existing stack members should retain their existing switch numbering.
You'll also will see the removed switch's configuration remain in the stack.  (This to allow easier replacement of a failed switch, with like model.)
Thiago Cardoso
Community Member
They will not renumber by itself.
First make sure once switch3 is removed and the stack ring is as it should be, follow guide line below
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/HIGINSTL.html
After your stack ring is up and running again do
show switch
make sure you see all ports up and and you will see swich 1 2 4 5
then you do
no switch 3 provision
switch 4 renumber 3
switch 5 renumber 4
and change the priotiry if you care
Make sure you do this off production hours.
Joseph's disclaimer apply to mine
