Switch Stacking
Jeff Horton
Level 3
Level 3
I am configuring switch stacks containing a c3850-24u and a c3850-12s... I have configured two stacks like this but they required two different interface configurations... One stack had the 24U as G1/*/* and the 12S as G2/*/*.. The other stack had the 24U as G2/*/* and the 12S as G1/*/*... Is there a configuration that needs to happen in order for all the configurations to be the same? I have look into switch priorities but that didn't seem to help.. Can someone guide me in the direction of setting this up?
Jeff
julijime
Hi Jeff,
If I understand correctly, you're looking on how to renumber the stack members. Having the 24U switches to be G1/*/*, is this correct?
In that case you would need to change the switch identity rather than the priority, and that can be achieved with the following commands:
Stack#switch 1 renumber 2
WARNING: Changing the switch number may result in a configuration change for that switch.  The interface configuration associated with the old switch number will remain as a provisioned configuration.  Do you want to continue?[y/n]y
Stack#switch 2 renumber 1
Stack#wr
Stack#reload
Please be aware that the interface configuration will not be swapped after you renumber the switches. So for example, if you had an Host connected to interface Gi1/0/1 after you renumber the switches, now Host will be connected to interface Gi2/0/1, however the configuration associated to interface Gi1/0/1 will not be ported to interface Gi2/0/1
Julio
julijime
Hi Jeff,
Stack#wr
Stack#reload
Julio
Thought I had tried that myself... I will give this another try and let you know what the results are.
Jeff
Hello
I agree with Julio
Rrenumber the switch(s) within the stack and also I guess a reload is required
res
Paul
Kind Regards
Paul
This is what I needed.. I figured out what I was doing wrong before.. I never did write the memory after the renumber commands.
Thanks for your directions....
Jeff Horton
