Switch stopped responding to ping through trunk port
fabioairoldi
Hey all,
I have several switches (Catalyst 9200) IOS version 17.10, all connected to a CORE switch (WS-C3850-24XS-E)
All 9200 are connected through trunk ports, whose native vlan i is the management vlan where all switches have IP adresses.
Now a few days ago, one (and only one) of those switches stopped responding to ping, while still working and forwarding traffic just fine.
As far as I know there were no changes to config both Core-side and 9200-side. By checking the configs of both the core and the 9200, everything is fine. If I connect directly to the 9200 on an access port configured on the management VLAN, I can ping it just fine.
If I issue show cdp neighbors on the core, I can see the non-pinging switch. The IP config and default gateway are properly configured, but from the non-pinging switch I cannot ping anything, not even my default gateway.
What's really stumping me is that every other 9200 has the same config and has no issues. What could I be missing?
thanks in advance
F.
I do not want to state the obvious, but very often, when these issues occur, rebooting the switch might help.
7 Replies 7
More likely
1- mgmt vlan not allow in trunk
Show interface trunk
2- vlan is missing or down
Show vlan breif
MHM
1 - No, show int trunk shows the VLAN allowed on the trunk just as it does on every other 9200
2 -No,unfortunately I had already checked that... VLAN is up and active (otherwise I wouldn't even be able to ping the switch by directly connecting to access port).
thanks for the reply anyway
any other ideas?
Can i see
MHM
Yeds, as this is a very crucial Switch to production, I was trying to avoid doing so; but if everything else fails I'll come in extremely early and try that.
@MHM Cisco World
SW_97#sh int tru
Port Mode Encapsulation Status Native vlan
Te1/1/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Te1/1/1 1-4094
Port Vlans allowed and active in management domain
Te1/1/1 1,5-12,17-18,20-23,30,40,50,60,70-72,75-76,79-84,86,90-91,101,110-111,127,210-215,220,230-231,240-241,301-308,311-314,350,401,430,508,550,900,920,999-1000
Port Vlans in spanning tree forwarding state and not pruned
Te1/1/1 1,5-12,17-18,20-23,30,40,50,60,70-72,75-76,79-84,86,90-91,101,110-111,127,210-215,220,231,240-241,301-308,311-314,350,401,430,508,550,900,920,999-1000
What is vlan you use for mgmt is it 230?
MHM
fabioairoldi
in the end I just found the right time to reboot, thanks for all the help.
