Switch supporting IOS 15
mcollins1983
Visitor
Hi.
I'm looking at buying some catalyst switches off eBay for labbing purposes. I'm just wondering what the lowest end switches that will support ios 15 and IP Services. I'm thinking WS-C3560G-24TS-E, as I don't think WS-C3560-24TS-E will support ios 15 - is that correct? Can any suggest a more appropriate model which is also cost-effective while also supporting ios 15 and IP Services?
Thanks.
I still have a Catalyst 3560-8PC in my Lab and it runs IOS 15. Just look at the download-section of the switch in question and you can see if an IOS 15 image is available.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
luis_cordova
Deepak Kumar
You can download the required IOS for your switch:
https://software.cisco.com/download/home/279486441/type/280805680/release/15.0.2-SE11
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
