Switch temperature reading from show env all command
cokho
Frequent Visitor
Frequent Visitor
On our 2960 switch and 3560 router, there is no inlet, outlet or hotspot temperature breakdown when I issue "show env all"
However, on the 9200, it shows inlet, outlet and hotspot temperature.
So what temperature is showing on the 2960/3560?
as per the cisco document suggest as below :
 Green indicates the temperature is normal or the device is not heating up and has good airflow.
BB
5 Replies 5
Leo Laohoo
RED, YELLOW & GREEN.
cokho
Frequent Visitor
Frequent Visitor
Here is what it shows:
SYSTEM TEMPERATURE is OK
System Temperature Value: 36 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 89 Degree Celsius
Red Threshold : 96 Degree Celsius
as per the output show good and Green, but the one you looking like other not possible on Cat 2960 as per i know.
Switch is end of life, but  you can see what temparature it can operate range :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/product_data_sheet0900aecd806b0bd8.html
BB
Thanks BB
So the temperature reported by the switch is the air temperature inside the switch?  Just try to relate the reading to the temperature spec.
BB
