Switch to Router Port Channel
gcarson73
I have one Cisco 2951 router and a Cisco 3750 switch.
The router has 3 GB interfaces, 1 interface to the ISP and 2 that I can use for a port-channel to the switch.  I cannot do any testing, since these are used in my "production" environment.  Any advice or input is appreciated.  See my proposed config for each device below.
*Config on Router
en
config t
interface port-channel 1
ip address 10.3.81.1 255.255.255.0
no shut
int g0/1
no ip address
channel-group 1
no shut
int g0/2
no ip address
channel-group 1
no shut
*Config on Switch
en
config t
no switchport
ip address 10.3.81.34 255.255.255.0
int range g1/0/23-24
no switchport
no ip address
channel-group 1 mode on
no shut
11 Replies 11
Mark Malone
are you sure those routers interfaces are capable of bundling? have logged in and checked is that command available under both ints you want bundle , i didnt think it was supported on 2951
I just used the following config on the router.  All looks good, on INT G0/2, I  used a different IP and did not apply to INT G0/1, since that is currently being used.  So that is a good sign this should work.
ip address 192.3.81.1 255.255.255.0
no shut
exit
int g0/2
no ip address
channel-group 1
no shut
exit
yes i had a look at one of our 2951s they have channel-group too just not protocol aware but no real need to be will still work fine, thought you may have needed a hwic but looks good , default route on the switch you should be all set
Thank you for checking.  The default route I have (for switch) is
ip route 0.0.0.0 0.0.0.0 10.3.81.1
Yes far side of the portchannel should be good , just make sure you can break out past that interface once applied from the locally connected devices in the switch , once your are your good and if not see where the trace stops that's most likely where the issue is occurring
Hello
Your L3 link aggregation config looks okay unless what Marks states is applicable and the router IOS doesn't support it?
Note: If it does support it , You may not be able to see any summary information using
sh etherchannel port-channel
                Channel-group listing:
but wth this:
sh interfaces port-channel 1 | in Des
  Description: TEST LAG
res
Paul
Kind Regards
Paul
devils_advocate
Level 7
Level 7
Are you having an issue or just asking if the config looks ok?
I have done a L3 port channel on a 2921 before so I can only assume its supported on the 2951.
The config looks fine to me, the Router cannot do Etherchannel negotiation, hence why the switch side has to be 'on'.
I would schedule a maintenance window though as its likely to blip any production traffic whilst the bundling takes place.
I am not having issues, I am just a 1 man IT person with a small company.  My background is VMware/servers.  We moved from a 2851 to a 2951 router and have the extra GB interface on the router.  I thought I might as well use it.
I applied the config to the switch, but the 2 ports are not connected to the router.  I will schedule some down time.  Will the bundling take a few  minutes?
Do I need any route statement on the switch?
Ahhh I see.
Configuring a Layer 3 port channel is like a point to point link between the Router and the Switch. The switch will need a default route towards the router and the router will need some static (or dynamic) routes for any subnets which exist on the switch.
In my router I have the route
ip route 0.0.0.0 0.0.0.0 99.3.81.1
so I should add (In my switch)
10.3.81.1 is interface IP (Channel-group on router), and other interface on router is 99.3.81.66, with the 99.3.81.1 being gateway for my ISP.
Yes that is correct.
