Switch to Switch Encryption
Info.cis
Frequent Visitor
Frequent Visitor
Hello
I have to establish an optical link with the traffic to be encrypted between two switches WS-C3850-48T and WS-C2960X-24PS-L. According to the specification, 2960 switches do not support MACSec. So, if there is any possibility for L2 encryption with our configuration?
Thank you.
Andrii
As the dedicated encryptors are typically quite expensive, I would also think about deploying a Catalyst C3560CX-8PC in addition to the 2960-X to implement MacSec on that device. If the 2960-X is enough for your general usage, this could be much cheaper than a completely new switch or 2 dedicated encryptors.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Leo Laohoo
You will need to get a pair of encryptors and deploy them at each end.
Otherwise, replace both switches with ones that support MACSEC.
Dear Leo,
Would you be also so kind to advise example model for such hardware encryptors?
Thank you in advance.
