switch to switch vlans
pkroetsch
I have separate cisco 3750 switches one is a 48 port and one is a 24 port switch.
I have the 48 port switch setup on a vlan.
interface Vlan95
ip address 192.168.95.1 255.255.255.0
then i have another 24 port switch setup as
interface Vlan55
description EMS DMZ
ip address 192.168.55.254 255.255.255.0
I want everything on vlan 55 to be able to talk to the 95 network on switch 1...the 48 port switch.
what is the best way going about doing this.
should i create another vlan on the 24 port switch as a 95 network to be able to talk to ether other.
interface GigabitEthernet1/0/18
switchport access vlan 55
switchport mode access
thanks for the help
2 Accepted Solutions
ALIAOF_
Level 6
Level 6
Connect the two switches using a trunk port.  Something like this:
3750 48 port
interface gi1/0/24
switchport trunk encap dot1q
switchport mode trunk
speed 1000
duplex full
ip routing
3750 24 port
interface gi1/0/24
speed 1000
duplex full
ip routing
vishal vyas
you need to type command # ip routing.. command in order to run inter vlan traffic.
15 Replies 15
ALIAOF_
Level 6
Level 6
3750 48 port
interface gi1/0/24
speed 1000
duplex full
ip routing
3750 24 port
interface gi1/0/24
speed 1000
duplex full
ip routing
ok then i don't need to assign a vlan to each since they on trunked together...
sorry I am new.
Yes trunk port will carry the VLAN's unless you restrict certain VLAN's in your case it sounds like a pretty simple setup.  You will need to assign the ports to the specific VLAN when you connect end devices though.
InayathUlla Sharieff
Hi Phil,
Since you are using different vlans that subnets needs to be preset if you want it to be communicated between each other.
If you just configure the vlans and apply to the access ports and allowed it over the trunk ports it will not get communicated between each other.
1- Configure the Vlans and allow it on the trunk interface.
2- Assign the vlans to the respective access ports.
3- Have the following subnets range on both the switches. (For example you need to have both the vlans on 2 switches with respective ip subnet ranges.)
4- Once you have them you should be good to go.
I have setup this on Packettracer let me know if you would like to have a look.
REgards
Inayath
*Plz rate all usefull posts.
Ok so I have the packet tracer up. Now I need to create new vlans on each switch?
Hi Phil,
I have configured everything on this devices on the pkt tracer file attached.You can check the configuration and connectivity.
Inayath
*Plz rate al uesfull posts.
I cannot ping each device... 95.10 cannot ping 55.10 and vise versa.
Thank you for the rating Phil were you able to get this up and running?
No Problem. I plan to give it a try this week.
HI Phil,
Were you able to use the Pkt tracer file?
Inayath
yes I opened it up but could not ping the computers. the 55.10 could not ping 95.10
Phil
Hi Phil.,
I just tested again and its all working end to end. Kindly open the file login to all the devices.
192.168.95.10 PC0----Switch 0=========Switch 1--PC1( 192.168.55.10 )
'PC0>ping 192.168.55.10 ----------------> PC to PC is pinging.
Reply from 192.168.55.10: bytes=32 time=4ms TTL=128
PC1>ping 192.168.55.10       ----------------> PC to PC is pinging.
PC0>
Switch0>
Vlan55                 192.168.55.253  YES manual up                    up
Vlan95                 192.168.95.1    YES manual up                    up
Switch0>
Switch1#
Vlan55                 192.168.55.254  YES manual up                    up
Vlan95                 192.168.95.2    YES manual up                    up
Switch1#
Kindly check the same and revert back if you face any issue.
Inayath
Thanks Inayath for the Pkt tracer, I just tested for myself and its working fine.
Was looking for somthing but this got some help for me.
Fari.
vishal vyas
