switch to tftp transfer
vishalpatil86
I am trying to copy startup config from access switch to mu pc where i installed tftpd
I have attached the network diagram....
When I copy startup from core switch to my pc, i am able to do it
but, when i try to copy the same from access switch to my pc, i cant
Pls help me on this. Let me know if u neeed any additional info
6 Replies 6
mrSS
is there a default gatway (192.168.10.254) on the access switch?
default gateway is 192.168.100.1 on access switch
Vishwa Mishra
Hi Vishal,
What error are you getting when you are copying image to your PC?
Do you see the tftp sever on Pc  showing any kind of error?
Also verify that you have connectivity from PC to switch (end to end ping).
Vishwa
there is no reachabilty betwn access switch and pc but i can ping pc from core switch
What are the vlan interface and its ip addresses at your core switch? You need to enaure there's reachability between the pc and the access sw before you can successfully establish tftp transfer. Lastly, check your pc's firewall, it may block incoming connection from different subnets.
thanks guys...
I sorted out the issue.  i put my pc into vlan 110 and gave IP 192.168.10.25 and gateway as 192.168.100.254
thanks for the help
