Switch Trucking with multiple connections
cursur949
I am a fairly basic configs that I just can’t figure out what I am doing wrong.  I have what I would consider a fairly basic config that I just can’t seem to get to work and I am sure it is something I am just not doing or grasping.   Basically I have two 3560 switches that I would like to connect together with four 1Gb ports and trunk four vlans across said port-channel, I created the port-channel and set it to switchport trunk encapsulation dot1q I then set all four ports to channel-group # mode on.  With that setup I can’t ping from switch to switch on the nonnative vlan.
Any help would be appreciated
interface Port-channel1
Something is missing in this line interface.  Can you please add "switchport mode trunk"?
6 Replies 6
The first thing I would do is reload the switches, no kidding. I've configured etherchannel before and just couldn't get it working and then I reloaded the switches and everything is workring fine.
If it doesn't work, post your configs.
Leo Laohoo
Please post the config.
cursur949
dc01-sw02#show run
Building configuration...
Current configuration : 2383 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname dc01-sw02
no aaa new-model
ip subnet-zero
port-channel load-balance src-dst-ip
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
switchport access vlan 128
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
switchport access vlan 240
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
channel-group 1 mode on
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
no ip address
interface Vlan128
ip address ###.#.#.### 255.255.255.0
ip default-gateway ###.#.#.###
ip classless
ip http server
end
dc01-sw02#
That worked, it is always seems to be and issue with just one line.
Glad to be of some assistance.
