you can not assign ip address to layer 2 interface in cisco 878
samnezamei
I have a cisco 878 router and I can’t assign ip address to it’s fast Ethernet interface. When I assign ip address give me this message: “you can not assign ip address to layer 2 interface”.
But I can not understand why give me this alert when I use a layer3 device?!!
paolo bevilacqua
You are using layer 3 device that has layer 2 interfaces. In this case, IP address is assgned to VLAN interface.
Note, if you have no previous experience, recommend you get support from someone that has, or study the product documentation.
paolo bevilacqua
OK
But how i can NAT my server to the wan connection & vice versa?
hrtbrkd310
Only one port on the 878 can be assigned an IP address the other ports under the yellow portion of the router are layer 2 only ports. The 878 is a soho router so setting up a NAT and using the 1 layer 3 port as the connection to your ISP. Just use a basic NAT set up. GL
