Switch trunk not working
ms69553924
Visitor
Hello Cisco Community,
currently I am trying to extend the configuration of two productive switches with a new vlan 190 and try to connect them via a new fiber cable. The firmware is quite old, but upgrading in the productive system would be not that easy to schedule.
Planned architecture:
Location A:
-) Switch SF300 (Firmware v1.3.0.62)
-) One client is connected via fastethernet port 26 and access mode to vlan190
-) Gigabit ethernet port 4 is connect with the switch of location B (via fiber), trunk mode vlan 190
Location B:
-) Switch SF250 (Firmware v2.1.0.60)
-) One client is connected via fastethernet port 1 and access mode to vlan190
-) Gigabit ethernet port 4 is connected to the switch of location A (via fiber), trunk mode vlan 190
The uplink on both sides to the clients in between the switches is working without issues. Currently we also have SSH access to the SF300, but we can not enable it for the SF250 (seems to be a firmware bug), so our options are limited here too.
We assigned an IP to the client at location A (SF300/26) and the same for the client at location B (SF250/1), but can not ping over the trunk between the switches. Pinging between client B and switch B is working (over the new vlan), we can not test it via client A and switch A, because we can not set a second ip interface for vlan 190 (seems like a firmware bug too, if we set it we loose the first set).
The current configuration is below, we also testet with access mode instead of trunks with the same result. In the configuration also "switchport mode trunk" is not shown, if I try to set it manually over the CLI it will not be shown anyway.
I am also not sure about the line "ip default-gateway 192.168.3.254" in the config of SF300 (location B).
Any hints what is going wrong here, would be great!
Configuration of Switch SF300 (Location A):
vlan database
vlan 61,180,190
interface vlan 1
no ip address dhcp
interface vlan 180
name X
interface vlan 190
name "Y"
ip address 192.168.2.1 255.255.255.0
interface fastethernet1
switchport access vlan 190
switchport trunk native vlan none
interface fastethernet2
switchport trunk native vlan 180
switchport trunk allowed vlan remove 1,190
interface fastethernet3
interface fastethernet4
interface fastethernet5
interface fastethernet6
interface fastethernet7
interface fastethernet8
interface fastethernet9
interface fastethernet10
interface fastethernet11
interface fastethernet12
interface fastethernet13
interface fastethernet14
interface fastethernet15
interface fastethernet16
interface fastethernet17
interface fastethernet18
interface fastethernet19
interface fastethernet20
interface fastethernet21
interface fastethernet22
spanning-tree link-type point-to-point
switchport trunk allowed vlan remove 190
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface fastethernet23
interface fastethernet24
switchport access vlan none
switchport trunk allowed vlan remove 1-21,23-4094
interface fastethernet25
interface fastethernet26
interface fastethernet27
interface fastethernet28
interface fastethernet29
interface fastethernet30
interface fastethernet31
interface fastethernet32
interface fastethernet33
interface fastethernet34
interface fastethernet35
interface fastethernet36
interface fastethernet37
interface fastethernet38
interface fastethernet39
interface fastethernet40
interface fastethernet41
interface fastethernet42
interface fastethernet43
interface fastethernet44
interface fastethernet45
interface fastethernet46
interface fastethernet47
interface fastethernet48
interface gigabitethernet1
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
switchport trunk allowed vlan remove 1-189,191-4094
vlan database
vlan 60,180,190
interface vlan 1
ip address 192.168.3.1 255.255.255.0
no ip address dhcp
interface vlan 190
name "Y"
switchport mode access
channel-group 1 mode on
switchport trunk allowed vlan add 190
switchport default-vlan tagged
interface Port-channel1
description "LAG 1"
interface Port-channel2
shutdown
description "LAG 2"
exit
9 Replies 9
Georg Pauwen
not sure I understand what you are asking. Which IP address do you want to ping from which IP address ? If you can narrow your post down, it would be easier to understand. Which switch (and IP address) do you want to ping from which switch (and IP address), using which trunk interface on each switch ?
Thank you for the fast reply.
My (not working) test set is:
Client A connected to switch A can not reach client B connected to switch B and the opposite.
I used vlan 190 for that. Access port from each switch to the client, trunk port between the switches.
IP client A: 192.168.2.10/24
IP client B: 192.168.2.11/24
IP switch A: 192.168.2.1/24
No firewalls locally on the clients
ICMP is running in timeout.
(No gateway)
Ping between switch A and client A works, Ping between switch A and B not.
The used ports are bold in my first post, at the config section.
you posted two configurations under the same header:
What is the IP address of Switch B ? And what is the configuration of Switch B ?
Thank you for the hint. Sorry for mixing up a little bit.
The first configuration is switch A, the second configuration is switch B.
Switch B just has:
interface vlan 1
no ip address dhcp
No ip for vlan 190 and it is not possible to add a second interface over the Web GUI or CLI. It just replaces the active configuration and we have to keep it in vlan 1.
I think the main problem is that we can not send packages through the trunk interface (gig4 in both configurations).
the only way an IP address in Vlan 1 and an IP address in Vlan 90 could communicate is if you have inter-Vlan routing configured on a different layer 3 device.
Ok, I try to describe the problem better.
Switch A:
1) added vlan190
2) connected to Client A:
3) connected to switch B:
Switch B:
1) added vlan190
2) connected with client B:
3) connected with switch A:
Then I assign ip 192.168.1.2 to client A and ip 192.168.1.3 to client B and try to establish any connection between those two. This does not work.
Thank you for your effort.
got it.
I think the problem is most likely related to the way the trunks are configured.
Can you try and configure both sides with just the minimal trunk configuration, where all Vlans are allowed ?
What I tried to accomplish is that (minimal config):
Accessports to the clients:
Trunkports between the switches:
In general this should do the trick?
But somehow over the webinterface the result from my last post comes to the config. Configuring via SSH is only at switch B possible (where we currently have this:
switchport default-vlan tagged)
I also tried it with accessports between the switches, without success. Unfortunately we can not send all vlans over the trunk, because we have some other connections between those switches (other vlans/ports).
