make disappier logging event link-status entry from running
Murxy
I am struggling with something which I belive should be easy to fix.
We are running a Network with cisco C9300-24P Switches with IOS Version 16.9.4
Config Template Looks like below
interface  Gi1/0/1
 description
 switchport access vlan 999
 switchport mode access
 switchport port-security violation  restrict
 switchport port-security mac-address sticky
 spanning-tree portfast
 shut
now some addet the command logging event link-Status to the interfaces
After removing the command with the no logging event link-Status the Interface config Looks like below
interface Gi1/0/1
 description
no logging event link-status
I would like to have the command not visible in the running config, same like after having set  the Port  to Default.
This because we have a compliance Job running on CW, which highlights me the difference.
We have many Ports which have the command applyed and I can't put the Port again to Default, because the Ports are all running and live in the Network.
Is there any command, which I can apply to let the logging Event disappier from the running config?
2 Accepted Solutions
balaji.bandi
You can do old IOS Global config.
may be you can try and let me know if that works ?
default logging event link-status
BB
Many Thanks!!! this made the Magic happen :-)
I did this on the Interface and Works
Much! appreciatet
Best regards
balaji.bandi
BB
Much! appreciatet
Best regards
