Vlan between 2960 and sg350
jmb09
Bonjour,
Je ne comprends pas comment propager les vlans d'un cisco 2960 vers un cisco sg350 ...
Toute aide est bienvenue merci,
I do not understand how to propagate vlan to an sg 350 from a 2960
All help is welcome thanks
balaji.bandi
SG350 do not support VTP client, you need to look other options as below :
GARP VLAN registration protocol (GVRP) allows devices to dynamically exchange VLAN configuration information to make the configuration of VLANs easier. When the switch receives VLAN information through GVRP and GVRP Registration, the receiving interface joins that VLAN. If an interface attempts to join a VLAN that does not exist and Dynamic VLAN creation is enabled, the switch automatically creates the VLAN.
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
BB
balaji.bandi
BB
Thanks for this help .... My "problem" is solved and i well understood gvrp.
Merci beaucoup
Thanks you ...
